i’m running a calculation that requires a hybrid potential, in particular a LJ and an EAM potential.
To minimize the system, i understand it’s highly recommended to use a LJ that goes to zero at the
cutoff. To insure this, one can use the pair_modify command in the form:
pair_modify shift yes
Does the shifting also works if the pair_style is hybrid? I mean, will LAMMPS “pick up” the LJ
defined in the pair_style?
To be more precise, these are the commands i’m using:
pair_style hybrid lj/cut 8.0 eam
pair_coeff 1 1 eam niu3
pair_coeff 1 2 lj/cut 0.023049 2.852
pair_coeff 2 2 lj/cut 0.002413 3.4
Miguel
