Hii all,
I have files “.h and. ccp” for the pair_style rebomos and i have added them in the src directory and compiled by using make mpi. Still the style is unrecognized.
Any solutions? Do i need some other files or packages?
Kind Regards
Hii all,
Kind Regards
What you did should be sufficient, so there must be something else wrong. I would suggest checking your setup by performing a test on a different pair style e.g. add/remove pair_lj_cut.cpp/h and run examples/melt in the same way.
