Hi, Steve and Axel,
I guess I understand why I was getting “bad grid of processors”, I remember making some silly mistakes like running with 8 processors but using a command “processors 2 1 2”. Thank you for pointing that out for me.
I am using MPICH v2 for the parallel computing. And yes, I tried to run it using only one processor, and it was fine (both with MPICH and without).
The following is the message printed on the screen when I run it on 8 processors:
LAMMPS (5 Jun 2010)
Reading data file …
orthogonal box = (-87.3235 -39.9476 -86.9681) to (87.3235 62 86.9681)
2 by 2 by 2 processor grid
225074 atoms
143706 atoms in group inner
50247 atoms in group fixed
1777 atoms in group indenter
145483 atoms in group output
29344 atoms in group outter
WARNING: Resetting reneighboring criteria during minimization
Setting up minimization …
rank 3 in job 30 compute-1-4.local_48018 caused collective abort of all ranks
exit status of rank 3: killed by signal 9
rank 2 in job 30 compute-1-4.local_48018 caused collective abort of all ranks
exit status of rank 2: killed by signal 9
And the following is my input script:
# 3d indenter simulation of CuNi indentation MM large indentation depth, step size 0.1 A
# energy tolerance 1e-12
boundary s s s
atom_style atomic
neighbor 0.3 bin
neigh_modify delay 5
# create geometry
read_data input.atoms_windent.cuni
mass 3 12.011
# potentials
pair_style hybrid eam/alloy/opt morse/opt 4.
pair_coeff * * eam/alloy/opt CuNiNbH.eam.alloy Ni Cu NULL
pair_coeff 3 3 morse/opt 0.100 1.7 0.22 3.
pair_coeff 1*2 3 morse/opt 0.1 1.5 4 3.55
# define groups
region 1 block -80.0 80.0 -22.5 40. -80.0 80.0 units box
region 2 block INF INF INF -22.5 INF INF units box
region 3 block INF INF 43. INF INF INF units box
region 4 block -80.0 80.0 -22.5 INF -80.0 80.0 units box
group inner region 1
group fixed region 2
group indenter region 3
group output region 4
group outter subtract all inner fixed indenter
# define compute and make y flexible boundaries
compute pot inner pe/atom
compute disl inner centro/atom fcc
compute load inner group/group indenter
#compute strsp inner stress/atom pair
fix 1 fixed setforce 0.0 0.0 0.0
fix 2 outter setforce 0.0 NULL 0.0
fix 3 indenter setforce 0.0 0.0 0.0
# relaxation
minimize 1.0e-14 1.0e-14 10000 100000
# totally fix all boundaries and apply indenter
fix 2 outter setforce 0.0 0.0 0.0
# control outputs
thermo 0
thermo_style custom step c_load[2]
dump 1 output custom 1000000 ./dump/dump.* id x y z c_disl c_pot type
dump 2 inner custom 1000000 dump.cuni id x y z c_disl c_pot type
# going into loop now
label iloop
variable iter loop 170
unfix 3
displace_atoms indenter move 0. -0.1 0. units box
minimize 1.0e-12 1.0e-12 10000 100000
next iter
jump in.cuni_w2.indent iloop
If you are interested, I can send my input data to you.
Thank you both again for your attention,
Shuai
