[lammps-users] Parallel tempering + NPT
Is NPT fix for parallel tempering not possible.
It gives me the following error
ERROR: Tempering fix is not valid
I went through the temper.cpp code, which tells
only nvt and langevin is possible.
Regards
Vishwas
well, in principle you can hack around this,
but the question remains, whether you would
generate a meaningful ensemble this way.
my memory is a bit hazy (i'm getting old), but
my recollection is that for parallel tempering
with npt, you'd also have a pressure based
exchange domain, i.e. some kind of 2-d parallel
tempering.
if i remember correctly, there should be some work
in the literature on this topic by dietmar paschek
and angel garcia.
cheers,
