Hello,i have a question, could you tell more about the parameter SEED ?
What exactly does this parameter mean? Is it a distribution number?
i have a command:
velocity flow create 1.0 482748 temp mobile
so, 482748 - what is it?
Are there any rules to specify this parameter?
Does a result depend from this parameter?
from the manual:
velocity command
Syntax:
velocity group-ID style args keyword value ...
group-ID = ID of group of atoms whose velocity will be changed
style = create or set or scale or ramp or zero
*create* args = temp seed temp = temperature value (temperature units) **seed** = random # seed (positive integer)
Thanks a lot, Sergey R.
