hello,i find there are mistake in the example of the command computer
tem/ramp. when i use this command for compute or temperature ,it says
the command can not find ,why? is it nor work?
The appended script (from bench/lj) works fine with
the compute temp/ramp command.
# 3d Lennard-Jones melt
variable x index 1
variable y index 1
variable z index 1
variable xx equal 20*$x
variable yy equal 20*$y
variable zz equal 20*$z
units lj
atom_style atomic
lattice fcc 0.8442
region box block 0 \{xx\} 0 {yy} 0 ${zz}
create_box 1 box
create_atoms 1 box
mass 1 1.0
velocity all create 1.44 87287 loop geom
pair_style lj/cut 2.5
pair_coeff 1 1 1.0 1.0 2.5
neighbor 0.3 bin
neigh_modify delay 0 every 20 check no
fix 1 all nve
compute 1 all temp/ramp vx 0 0 y 0 10
thermo_style custom step temp c_1
thermo 10
run 100
2008/12/12 H.Q. Lu <[email protected]...>:
