Dear All
Hi
I hope that all of you will be successful in your works. I have two questions.
1- my Images and movies from XMOVIE are very very small and I can not give a good snapshot or movie.How can i give a good image and movie? (For example for POUR example)
2- For POUR example i am going to pouring grains from top of one side of box.How can I do it? (For example I am going to pour the granular particles from top and left side of the block box. but i can not do it).
With the best regards
Hamed Maleki
Hamed Maleki
Physics department, Faculty of Science,
University of Birjand, Birjand, Iran
              Hamed,
You probably need to be using the -scale option. See
the xmovie README file:
"Note that LAMMPS output is scaled by default (so
all coordinates are from 0 to 1).  Thus you need to
run xmovie like this:
xmovie -scale dump.*
to see the snapshot you expect"
not do it).
Specify a region at the top left side of the box using
the region command:
http://www.cs.sandia.gov/~sjplimp/lammps/doc/region.html
Then insert your granular particles using fix insert:
http://www.cs.sandia.gov/~sjplimp/lammps/doc/fix_insert.html
Paul
              Hello everyone,
I have a question regarding a logical in temp/rescale. I pasted a part of
the subroutine where the temperature is scaled.
    if (iregion == -1) {
      for (int i = 0; i < nlocal; i++) {
  if (mask[i] & groupbit) {
    } else {
  if (mask[i] & groupbit &&
      domain->regions[iregion]->match(x[i][0],x[i][1],x[i][2])) {
What does the check for iregion == -1 mean? When the condition is not
fulfilled does the additional check
domain->regions[iregion]->match(x[i][0],x[i][1],x[i][2])) mean to check
whether the atoms belong also to the geometrical region in space originally
defined for a particular region id? Why are two different checks necessary
based on the value of iregion?
Jaime Sanchez
              The fix temp/rescale command has an option to apply the rescaling
only to a geometric region.  This was added with the 16 May 06 patch.
So the section of code you include checks whether a
region was specified (iregion >= 0) or not (iregion = -1).
