I intall the lammps with fftw-2.1.5. There isnot error as I install it. However, when I do the test with /examples/peptide in the lammps software. The strange errors appear, which are listed as follows:
The output (if any) follows:
LAMMPS (9 Jan 2009)
Scanning data file …
3 = max bonds/atom
6 = max angles/atom
14 = max dihedrals/atom
1 = max impropers/atom
Reading data file …
orthogonal box = (36.8402 41.0137 29.7681) to (64.2116 68.3851 57.1395)
2 by 2 by 4 processor grid
2004 atoms
2004 velocities
1365 bonds
786 angles
207 dihedrals
12 impropers
Finding 1-2 1-3 1-4 neighbors …
4 = max # of 1-2 neighbors
7 = max # of 1-3 neighbors
14 = max # of 1-4 neighbors
18 = max # of special neighbors
Finding SHAKE clusters …
19 = # of size 2 clusters
6 = # of size 3 clusters
3 = # of size 4 clusters
640 = # of frozen angles
84 atoms in group peptide
PPPM initialization …
G vector = 0.268721
grid = 15 15 15
stencil order = 5
RMS precision = 4.86052e-05
WARNING: Reducing PPPM order b/c stencil extends beyond neighbor processor
G vector = 0.266021
grid = 18 18 18
stencil order = 4
RMS precision = 5.61544e-05
brick FFT buffer size/proc = 1960 648 2352
Setting up run …
SHAKE stats (type/ave/delta) on step 0
4 1.111 1.44264e-05
6 0.996998 7.26967e-06
8 1.08 1.32536e-05
10 1.111 1.22749e-05
12 1.08 1.11767e-05
14 0.96 0
18 0.957206 4.37979e-05
31 104.519 0.00396029
WARNING: Shake determinant < 0.0
Memory usage per processor = 7.53338 Mbytes
---------------- Step 0 ----- CPU = 0.0000 (sec) ----------------
TotEng = 69910992907538569926244983351885057838284966357914337004224512.0000 KinEng = 1134.9186 Temp = 282.1005
PotEng = 69910992907538569926244983351885057838284966357914337004224512.0000 E_bond = 16.5572 E_angle = 36.3726
E_dihed = 15.5190 E_impro = 1.9426 E_vdwl = 692.8945
E_coul = 69910992907538569926244983351885057838284966357914337004224512.0000 E_long = -33567.2858 Press = nan
Exit code -5 signaled from b326
MPI process terminated unexpectedly
Killing remote processes…ERROR: Out of range atoms - cannot compute PPPM
DONE
Signal 15 received.
In addition, the errors always appear as long as I use the PPPM arithmetic. Why?
