I am trying to calculate the pressure on a particular group of atoms using
the stress tensor example in the documentation. However when I try to get
the difference in pressure between the start of the run and the current
step, it gives the following error message:
p0_18942: p4_error: interrupt SIGSEGV: 11
Here is a code snippet, where it fails on the last line:
compute s all stress/atom
compute p all reduce sum c_s[1] c_s[2] c_s[3]
variable pressure equal -(c_p[1]+c_p[2]+c_p[3])/(3*vol)
variable diffPressure equal v_pressure-${pressure}
Using the global thermo pressure compute value works fine, but I want to be
able to calculate the pressure for a subgroup of atoms.
I am using version 21 May 2008. Is there something obvious that I'm missing?
Thanks in advance for your help.
Regards,
Anna.
