[lammps-users] Problem compiling LAMMPS with REAX on AIX
Dear list members,
I am trying to compile LAMMPS with REAX on AIX using the mpCC_r compiler for C++ codes and xlf for fortran codes (in reax library-folder). The reax library (libreax.a) is built successfully. However when I compile, after including and linking the reax library, I get errors in all statements in which "FORTRAN" appears (files 'pair_reax_fortran.h' and 'pair_reax.cpp' are the ones affected). The compiler replaces the occurance of "FORTRAN" by "_".
The question you need to answer is how to compile/link
any C++ code with any Fortran code on your box. If you
figure that out (e.g. from the compiler manuals), then
you should be able to do it with LAMMPS + ReaxFF.
Thanks for the heads up.
I could compile lammps + reax by a minor edit in the file pair_reax_fortran.h by doing the following:
Original
