Dear LAMMPS users,
I'm trying to write a diagnostic for the Stillinger-Weber potential,
which I want to implement as a compute (comnpute_sw_test.cpp).
Unfortunately I'm having problems initializing objects of the class
PairSW in my compute. For example, in the loop over neighbors
pair_sw.cpp contains the line
itype = map[type[i]];
and map is declared in pair_sw.h as
class PairSW : public Pair {
private:
int *map;
By analogy my compute contains the line
itype = force->pair->map[type[i]];
but LAMMPS crashes with a memory access failure when it reaches this
line. The debugger gives the error message "force should have been
initialized in a superclass ctor". Simply redefining map as public in
pair_sw.h and in pair.h doesn't solve the problem, and anyway I'm not
sure what declarations I should make in compute_SW_test.h. I get similar
problems with the array elem2param, the functions twobody and threebody
and the structure params, all of which are also defined as private in
pair_sw.h.
What changes do I need to make in order to access the objects of PairSW?
I attach my stripped-down code for compute_sw_test to illustrate what
I'm trying to do, and style.h. The changes I made to style.h are
indicated with the phrase "begin/end Philip's changes".
For the record, a similar diagnostic for the pair interaction
pair_lj_cut.cpp works without any problems. pair_lj_cut.h contains the
declaration
class PairLJCut : public Pair {
public:
void single(int, int, int, int, double, double, double, int, One
and pair.h contains the declaration
class Pair : protected Pointers {
public:
Pair(class LAMMPS *);
virtual ~Pair() {}
force->pair->single(i,j,itype,jtype,rsq,factor_coul,factor_lj,1,one);
and my diagnostic happily executes the line
Many thanks in advance for any help you can give me.
Philip
PS: I wrote my compute before the release of 15 December 2007, so it
still assumes the old-style structure of the neighbor lists. Obviously
I'll change this to make it compatible with the newversion, but that
has nothing to do with the above problem.
pair.h (4.84 KB)
compute_SW_test.cpp (5.08 KB)
compute_SW_test.h (1.2 KB)
