Hi! Hope this list is not restricted to the C++ version! I am having a strange problem running (FORTRAN) LAMMPS01 using the angle-swapping routine (used for equilibrating polymer melts). The problem centers on use or nonuse of the following command in the input script:
############### BONDSWAP INPUT ######################
# frac - fraction of atoms examined for swap
# cut - < FENE cutofff
# frac cut seed
diagnostic bondswap 100000000 none 3 0.5 1.3 820691
