I tried to start a quite complicated simulation with pair_style hybrid reax and lj/cut/coul/cut. In pair_coeff I defined for reax that one atom type should be NULL to define it later for lj/cut/coul/cut. But when the Simulation starts LAMMPS writes me: ERROR: Invalid REAX atom type. When I try it with reax/c I get an Segmentation Fault. In attachment a very simplified and impractical input script of my original input.
The second error is when I write in pair_style hybrid checkqeq no for reax/c, LAMMPS doesn't recognize it as an input and crashes. (e.g. pair_style hybrid reax/c ctrl.reax checkqeq no lj/cut/coul/cut 10.0 8.0).
data-file:
LAMMPS data file. Generated by writelmp_data.m
2 atoms
2 atom types
0.000000 10.000000 xlo xhi
0.000000 10.000000 ylo yhi
0.000000 10.000000 zlo zhi
Masses
1 1.008000
2 15.999000
Atoms
1 0 1 -0.80000 2.000000 2.000000 2.000000
2 0 2 0.800000 7.000000 7.000000 7.000000
LAMMPS Input:
# (1) Initialisierung
robert,
i have reproduced the issues that you are reporting and
looked the corresponding LAMMPS sources.
what you describe is effectively a so-called "undocumented feature".
neither reax nor reax/c currently seem to have proper support
for the hybrid potential use that you are attempting.
in the case of reax there is a test in the code, in the case of reax/c
there is no test which will then lead to the segmentation fault.
confirmed as well. not sure what is needed to make this work.
overall, it looks like you are currently between a rock and a hard place.
you may be able to get away with adding a dummy atom type to
the reax.ffield file for the atoms that you want to be ignored for
reax, but i don't even know that that 'can' work, or you may need
to change the reax or reax/c implementation to skip over atoms
that are flagged with type -1.
I'll look into this. The author of the user reax/c probably
didn't think about pair hybrid.
