dear lammps users,
i am unable to read the coordinates file in vmd.the error reads ‘unable to load molecule 1’.i dont know wat seems to be the problem.the dump file is enclosed.thanks in advance
vishnu
dump.bending (53.5 KB)
dear lammps users,
vishnu
dear lammps users,
dear vishnu,
'unable to load molecule 1'.i dont know wat seems to be the
your problem seems to be one of the PEPCAC type.
a) this is a VMD problem and not a LAMMPS problem
b) to get proper help, you need to describe what
_exact_ steps you did, so that somebody can
reproduce the error, or see what your problem is.
c) VMD will read this file just file, _if_ you tell
it that it is a LAMMPS file. since your file name
provides no indication of what type it is, VMD
fall back to assuming a .pdb format file, which
your file definitely isn't, so you get an error.
this is well documented in the VMD user's guide.
d) the VMD documentation (online and shipped) provides
detailed instructions on how and where to report problems.
again, there is nothing wrong with the file or VMD.
cheers,
hi
i have a similar problem a week ago, my problem was that i use a old version of VMD, the last version of lammps have some change in the output structure of dump file (i think).
other thing that happen to me is that the matlab program 'readdump_one.m' don't can open a dump file with option -1 (read the last position).
bye.
hi
the example data file was produced with an old version of LAMMPS
and thus is compatible to older versions of VMD.
last position).
the e-mail address of the author of those (contributed!) matlab scripts
is given in the README.pdf file. i suggest you contact him.
cheers,
