hi.
in a simulation with 5000000 of atoms lammps give me
the next error:
LAMMPS (22 Jan 2008)
Scanning data file ...
Reading data file ...
orthogonal box = (-31 -31 -1) to (31 31 33)
1 by 1 by 1 processor grid
5905302 atoms
0 = max # of 1-2 neighbors
0 = max # of 1-3 neighbors
0 = max # of 1-4 neighbors
1 = max # of special neighbors
5905302 atoms in group bloque
33346 atoms in group suelo
WARNING: Resetting reneighboring criteria during
minimization
Setting up minimization ...
p0_6380: p4_error: interrupt SIGSEGV: 11
i don't know, if this error are giving for lammps or
for the computer. someone could tell me what means
this error.
thank you.
???> hi.
???> in a simulation with 5000000 of atoms lammps give me
???> the next error:
???> Setting up minimization ...
???> p0_6380: p4_error: interrupt SIGSEGV: 11
???> i don't know, if this error are giving for lammps or
???> for the computer. someone could tell me what means
???> this error.
segmentation fault happens when you access memory that
you are not allowed to. it could be that you have hit
a limit in your MPI implementation or that you are
simply running out of memory. you seem to be using
MPICH (use OpenMPI instead, it is _much_ better, BTW)
which also has a tendency to segfault whenever there
is a failure.
i'd recompile LAMMPS with the bundled STUBS library
to see whether to blame the MPI library. if you still
get a segfault, you should enable core dumps and
use a debugger to find out where it fails.
cheers,
???> thank you.
???> ______________________________________________
???> Enviado desde Correo Yahoo!
???> M�s formas de estar en contacto. http://es.docs.yahoo.com/mail/overview/index.html
???> Check out the new SourceForge.net Marketplace.
???> It's the best place to buy or sell services for
???> just about anything Open Source.
???> http://ad.doubleclick.net/clk;164216239;13503038;w?http://sf.net/marketplace
???> _______________________________________________
???> lammps-users mailing list
???> [email protected]
???> https://lists.sourceforge.net/lists/listinfo/lammps-users
I'd run a smaller problem to see if you can reproduce/debug
the issue.
--- Steve Plimpton <[email protected]> escribi�:
reproduce/debug
the issue.
> hi.
me
> the next error:
> 5905302 atoms
> minimization
or
means
> this error.
> thank you.
hello
i try simulate other problem more little (with only
388772 atoms and gime me the same problems:
with run:
[email protected]...:~> lmp_qed < in.ganinn
orthogonal box = (-13 -13 -1) to (13 13 15)
388772 atoms
388772 atoms in group bloque
5372 atoms in group suelo
Setting up run ...
p0_11642: p4_error: interrupt SIGSEGV: 11
with minimice
388772 atoms
minimization
p0_13236: p4_error: interrupt SIGSEGV: 11
i also send the same problem to the cluster with 8
processor and give my the next output:
2 by 2 by 2 processor grid
388772 atoms
minimization
p7_6617: p4_error: net_recv read: probable EOF on
socket: 1
rm_l_7_6632: (3.429688) net_send: could not write to
fd=5, errno = 32
p1_16524: p4_error: net_recv read: probable EOF on
socket: 343
rm_l_1_16539: (4.257812) net_send: could not write to
fd=5, errno = 32
p2_29415: p4_error: interrupt SIGSEGV: 11
rm_l_2_29430: (4.109375) net_send: could not write to
fd=5, errno = 32
i send you the files used in this problems, can
someone tell me where is the error becouse the cluster
have 80X8GB.
the data file have 16GB
thank you for all.
in.ganinn (3.74 KB)
GANINN.sw (2.3 KB)
Can you post the smallest version of your problem
that crashes with the run command: input script/data file.
2008/4/2 no tengo nombre <[email protected]...>:
Your simulation has a box of size 10000 cubic Angstroms
with 380K atoms in it. In other words, 35 atoms per
cubic Angstrom. I don't think that's GaN.
For normal Stillinger-Weber cutoffs of a few Angstrom's
this is generating monstrous neighbor lists, which is
causing the crash. If you set
neigh_modify page 1000000 one 100000
you can make it run w/out overflowing the normal
max neighbors/atom assumption.
You're also running with the "nsq" neighbor list
option which will be extremely slow, especially
when you try to run your 5M atom problem.
hello.
i put the next line in my previous script:
neigh_modify one 8250 page 82500
and don't give me te previous error but, now a don't
can allocate all memory for the simulation, the system
give me core dumped in the cluster and in a computer
with 4GB RAM i see the system monitor and the lammps
process assign memory up to 2'7 GB and fail with the
message:
Failed to allocate 100000 bytes for array
neightlist:pair[i]
do you know some metod for lauch the process with more
memory
thank you.
Angstroms
Angstrom's
is
> > reproduce/debug
> > the issue.
> > Steve
> > > hi.
give
> > me
> > > the next error:
> > > 5905302 atoms
during
> > > minimization
lammps
> > or
> > means
> > > this error.
> > > thank you.
> hello
only
> with run:
> 388772 atoms
> Setting up run ...
> with minimice
> 388772 atoms
> minimization
8
> 388772 atoms
> minimization
on
> socket: 1
to
> fd=5, errno = 32
on
> socket: 343
write to
> fd=5, errno = 32
write to
> fd=5, errno = 32
cluster
> have 80X8GB.
> thank you for all.
> �Con Mascota por primera vez? S� un mejor Amigo.
Entra en Yahoo! Respuestas
Yahoo | Mail, Weather, Search, Politics, News, Finance, Sports & Videos
> # simulacion de estructura INAS pura comprimida
(con paredes y sin paredes y luego sin comprimir)
> dimension 3
> boundary s s s
> newton on
> neighbor 2 nsq
> processors 2 2 2
> #neigh_modify delay 5
> atom_style molecular
> pair_style sw
> units metal
> #lectura de estructura
=== message truncated ===
If you're running out of physical memory, you can't run that big
a problem. You never answered the question as to why your
atom density is so unphysically high.
hello.
i solve the problem in my simulation, changing the
scale (nm to anstrom).
but now the simulation give me other error the atoms
take NaNs positions.
i send the new scrip and dump file.
also, i change the input data file for other and the
simulation run perfectly.
what could be the problem?
thank you for all.
dump.ganinn (475 KB)
GANINN.sw (2.3 KB)
in.ganinn (873 Bytes)
log.lammps (1.52 KB)
data.ganinn2 (364 KB)
