Dear Joanne and Vikas,
From Sun's paper about COMPASS referenced in the LAMMPS User Manual,
PCFF and COMPASS force fields were constructed allowing atoms separated
by two or more atoms to have pairwise interactions. So, using
"special_bonds 0 0 1" to allow the end atoms of (1-4) dihedral
interactions to contribute to pairwise interactions sounds most
appropriate!
Thank you both for your assistance,
Paul
"Budzien, Joanne
Louise"
<[email protected]... To
> Paul Harten/CI/USEPA/[email protected]...,
"Vikas Varshney"
11/13/2008 10:50 <[email protected]...>
AM cc
"[email protected]...
et"
Subject
Re: [lammps-users] pure ethanol
Dear Paul,
Use the special bonds command to add bonded atoms to the pairwise
neighbor list.
Joanne Budzien
Dear Vikas,
For a particular atom, aren't all atoms involved in bonded
interactions
excluded from non-bonded interactions? How were you able to add
those
atoms involved in dihedral interactions to the pairwise neighbor
list?
Thank you for your suggestions and your explanations,
Paul
"Vikas Varshney"
To
11/10/2008 10:34
cc
PM
t
Subject
ethanol
Dear Paul,
By 1-4 interactions, I mean dihedral interactions, (between 1st
and 4th
atom along the chain)... they are evaluated as non-bonded
interactions
(columbic and van der waals, both) on the top on bonded
interactions.?
Regards,
Vikas
Dear Vikas,
A colleague of mine who did a Materials Studio MS NPT run on
pure
ethanol got a density close to 0.78 g/cm3 at 298 K and 0.0 atm.
In your side note, you suggest that for the PCFF force field I
need to
incorporate 1-4 interaction as non-bonded in LAMMPS. What are
the 1-4
interactions you are referring to?
Paul
"Vikas Varshney"
To
11/10/2008 01:25
cc
PM
t
Subject
ethanol
Dear Paul,
Does material studio gives you the correct density?
Just on the side note which may help you. For PCFF force field,
you
need
to incorporate 1-4 interactions as non-bonded in lammps. That is
what
I
found out when I tried to match energies in MS and LAMMPS.
Regards,
Vikas
