Dear lammps users,
Did anybody mentioned changes in "fix ave/spatial" command in lammps
version 7Jul09.
According to manual delta in this command supposed to be distance
units and it was in lammps version 6Dec08 I used before.
Now then I use input file
lattice sc 4.329
replicate 160 4 4
fix 4 all ave/spatial 1 80000 100000 x lower 8.658 v_temp file tmp.profile
the tmp.profile looks like:
# Spatial-averaged data for fix 4 and group all
# TimeStep Number-of-layers
# Layer Coordinate Natoms v_temp
100000 19
1 18.7402 1099.29 2167.46
2 56.2207 1119.93 2201.58
3 93.7012 1091.7 2206.99
4 131.182 1116.36 2166.05
5 168.662 1118.14 2190.55
6 206.143 1090.01 2205.26
7 243.623 1119.86 2206.52
8 281.104 1105.94 2211.05
9 318.584 1102.06 2192.13
10 356.065 1120 2163.22
11 393.545 1094.99 2142.59
12 431.026 1113.01 2143.92
13 468.506 1119.97 2144.27
14 505.987 1091.24 2173.83
15 543.467 1116.8 2173.49
16 580.947 1118.43 2155.69
17 618.428 1089.81 2167.3
18 655.908 1119.76 2181.56
19 693.389 532.713 2154.26
as you can see it's in the units of lattice parameter.
Then I restart from saved file delta is interpreted in some other units.
I would really appreciate any help.
Is it defect of my compilation or some bug in the new version of fix
ave/spatial command.
German Samolyuk
According to the doc page, the default units for this
command is "lattice", not box. So the output looks
correct to me. This default setting is the same for
all commands that have a "units" option. But I think
you are correct that fix ave/spatial was not originally
that way (box was the default, not lattice).
Possibly at the last release we changed it
to be consistent and failed to list it on the patch page.
There was a also a 18May08 bug patch that might
have affected your output.
Thank you,
If I restart my calculations with read_restart command
the command fix ave/spatial changes output even if I use it with definite units
fix 4 all ave/spatial 1 180000 200000 x lower 2 v_temp units
lattice file tmp.profile ave running
The version of lammps I use is 7Jul09. Does it mean that it has a
18May08 bug patch?
German
Restart file don't store anything about the fix ave/spatial
command or the lattice. So your new script would
have to re-define these quantities. Any LAMMPS version
dated after a patch will contain the patch.
Yes, I understand.
I input script I re-define fix ave/spatial after restart with command
but it's different units.
German
I don't understand what you're asking. If you use the same
units and lattice and fix ave/spatial commands in both scripts,
what is it doing different? The only difference
could be that the lower x boundary is different when restarting,
if the box volume changed.
If I use units box
"fix 3 all ave/spatial 1 399 400 x lower 10.86 v_temp units box
file tmp.profile ave running"
It's restarting correctly.
If I use units lattice
"fix 3 all ave/spatial 1 399 400 x lower 2.0 v_temp units
lattice file tmp.profile ave running"
it does something different on restart
German
PS: It's not a big deal as soon as I can use "units box"
I still don't know what you mean by this. If you
put the exact same commands (lattice, fix ave/spatial)
in 2 different input scripts you should get the same behavior.
The fact that you started one from a data file and the
other from a restart file makes no difference (assuming
the box size is the same, and assuming the atom info
is similar). Neither of those commands know anything
about a data or restart file.
I prepared simple example:
1) input file
lattice fcc 5.39
region box block 0 1 0 1 0 1
create_box 1 box
create_atoms 1 box
mass 1 39.948
timestep 0.002
replicate 2 1 1
pair_style lj/cut 13.0
pair_coeff 1 1 0.010324 3.405
thermo 1
velocity all create 90.0 87287
compute ke all ke/atom
variable temp atom c_ke[]/(1.5*8.67e-5)
fix 3 all ave/spatial 1 9 10 x lower 1.0 v_temp units
fix NVE all nve
restart 10 rstrt_1 rstrt_2
run 100
2) OUTPUT tmp.profile
10 2
1 2.695 5 69.6502
2 8.085 3 90.3541
20 2
1 2.695 5 65.6061
2 8.085 3 85.5567
30 2
1 2.695 5 58.1182
2 8.085 3 76.9617
3) restart from rstrt_1 input file
lattice fcc 5.39
thermo 1
read_restart rstrt_1
fix NVE all nve
run 100
4) OUTPUT tmp.profile
100 12
1 0.452683 2 1.69452
2 1.35805 0 0
3 2.26341 2 13.5428
4 3.16878 0 0
5 4.07414 0 0
6 4.97951 2 18.4495
7 5.88487 0 0
8 6.79024 0 0
9 7.6956 1 11.1759
10 8.60097 1 16.0933
11 9.50633 0 0
12 10.4117 0 0
110 12
1 0.452683 2 1.2671
2 1.35805 0 0
3 2.26341 2 18.4736
4 3.16878 0 0
5 4.07414 0 0
6 4.97951 2 23.6849
7 5.88487 0 0
8 6.79024 0 0
9 7.6956 1 11.7887
10 8.60097 1 12.5643
11 9.50633 0 0
12 10.4117 0 0
I keep the same units lattice
German Samolyuk
Thanks for sending the example. LAMMPS is actually
working correctly.
In your first script you have:
lattice fcc 5.39
create_atoms 1 box
In your second script you have:
lattice fcc 5.39
read_restart tmp.1
In the first case, the lattice is setup in metal units, where 5.39 means
the lattice spacing is 5.39 Angs.
In the second case, the lattice is setup in lj units (the default), where
5.39 is the reduced density, which generates a very small lattice
spacing. Then reading the restart file will change your units
to metal. So if you flip the order of the lattice and read_restart
commands in the 2nd script, you'll get what you want.
If you look at the output printed to the screen by the lattice
command, you'll see what it generates for spacings.
This confused me at first as well, but it's a "feature" not a "bug".
Steve, thank you very much!
German
