If I run the following script (adapted from yours),
I get identical time 0 thermo output (energy, pressure)
on 1,2,10,20 procs. So I do not see the ouptut issue you list.
Are you running the most current version of LAMMPS?
Re: the other issues with hi-temp runs (8000K). I'm going
to wait for the Stuart group to weigh in on any bugs they
find versus their code. They have mentioned some small
issues with high-temp. But there are other pitfalls with
setting up the system and NVT for running at high T,
so it could also be your model that is at fault
# test script
lattice diamond 3.57
region box block 0 5 0 5 0 5
create_box 1 box
create_atoms 1 box
mass 1 12.011
neighbor 0.5 bin
pair_style airebo 3.0 0 0
pair_coeff * * ../potentials/CH.airebo C
velocity all create 100.0 123456789 dist gaussian units box
fix 1 all nve
thermo 1
timestep 0.0001
run 0
2010/9/8 黄德明 <[email protected]...>:
