Lammps users:
Is there a way to alias an atom type for fix_rdf?
I have two different carbonyl carbon types in my system, but for the RDF, I’d like them to be looked at as the same atom type. In other other words, I don’t want an ester-ester RDF, a acid-acid RDF, and a ester-acid RDF, I just want a carbonyl-carbonyl RDF.
Can lammps do that? I have a code to write out RDFs from dump files, but it is brute force and slow. Rather let lammps do it for me.
If there isn’t, thanks anyways.
Kevin
Lammps users:
how large is your data set?
have you tried the RDF code in VMD?
it allows you to pick atoms in very flexible ways,
and is multi-threaded on the CPU and supports
(multiple) GPUs, too, if you have them.
http://dx.doi.org/10.1016/j.jcp.2011.01.048
cheers,
The doc page for compute rdf explains that you can use a wildcard
notation for specifying the atom type. E.g. if you carbonyl C
are types 1 and 2, you can ask for the rdf of 1*2 with 1*2.
I the types are 10 and 15, then you're out of luck.
