In setting up a new input file today that used the read_restart command I was surprised to see that that the restart file used must be located in the same directory as the input script. I took a look in the code as well and confirmed this (as far as I could tell).
All other instances where a file is specified (as far as I have found) can be specified by either relative or absolute pathnames, which is what made this instance surprising.
Clearly this not a big deal, or even a bug, but I thought I might flag it up. Is there a reason why the restart file location is restricted like this?
Dan
