[lammps-users] restart2data Error
Dear All,
The restart2data does not work in the most recent version of Lammps.
the error message is:
"ERROR: Invalid flag in type arrays section of restart file 1072693248"
I guess that this error is related to the machine on which I run the
code, because I never have such a problem when I run on a 32 bit
computer. Also Lammps is able to read the same restart file with
read_restart command even on 64 bit machine.
I do not know if I should use a particular option when I compile
Lammps (restart2data) on 64 bit machine or probably this error is due
to a bug. Do you have any idea?
I am using the most recent version of Lammps (26Mar09) for energy minimization.
Majid.
The current version works for me in a simple test. You'll have
to give more details.
