I’ve been trying to start a simulation with a hybrid of AIREBO, Tersoff and LJ potentials. I noticed that when I switch on the LJ option in the AIREBO function, the simulation doesn’t run on my cluster. However, when the LJ option is switched off, it runs perfectly okay on the cluster. The simulation starts fine with the torsion option switched on or off.
Strangely, this problem does not show up when run on a serial version of LAMMPS i.e. switching on/off the LJ option doesn’t affect anything.
Has anyone encountered a similar problem or has any idea why things are like that?
Regards,
Zhun-Yong
What do you mean by it doesn't run? An error, a crash, it hangs?
It hangs when the LJ option is switched on but runs when the latter is switched off.
Zhun-Yong
2008/8/18 Steve Plimpton <sjplimp@…24…>
Can you post the data file the input script reads in?
This was a bug when using pair_style airebo as part of pair_style hybrid.
Just posted a 19Aug08 patch that seems to fix it. Also, you probably
want to use pair_style hybrid and not hybrid/overlay in your script, since
you aren't using two potentials for any interaction between the same two
atoms.
Hi Steve,
Thanks for fixing this bug. It's a real lifesaver.
Zhun-Yong
2008/8/19 Steve Plimpton <[email protected]...>:
