This is the first time I am using lammps. I get a segmentation fault as soon as I start the simulation. I use the comman:
lmp -in in.melt-nvt-1
This is the input script:
units lj
dimension 2
atom_style bond
read_data /fs/home/sm868/lammps_melting/data.melt-nvt-1
mass 1 1.0
velocity all create 1.0 87287 dist gaussian
pair_style lj/cut 1.1225
pair_coeff 1 1 1.0 1.0 1.1225
pair_modify shift yes
neighbor 0.1 bin
neigh_modify delay 2 every 10 check yes
neigh_modify exclude molecule rigid
fix 1 all nvt 1.0 1.0 100
fix 2 all enforce2d
fix 3 all shake 0.0001 100 10 b 1 t 1
compute 1 all coord/atom 2.0
compute 2 all rdf 100
timestep 0.001
thermo 100
run 100000
dump 1 all xtc 10000 /fs/home/sm868/lammps_melting/dump.melt-nvt-1
log 1 /fs/home/sm868/lammps_melting/log.melt-nvt-1
dump_modify 1 every 25
