I have compiled lammps locally and I have an inputfile that gives
sigsev. I would be grateful for some help. I have attached my
inputfile, some output from gdb as well as my makefile.
Thanks in advance
Niels
***************** My input file *********************
[[email protected]... bench]$ cat in.lj20000x4
# 3d Lennard-Jones melt
variable x index 31.748
variable y index 31.748
variable z index 31.748
units lj
atom_style atomic
lattice fcc 0.8442
region box block 0 $x 0 $y 0 $z
create_box 1 box
create_atoms 1
mass 1 1.0
velocity all create 1.44 87287 loop geom
pair_style lj/cut 2.5
pair_coeff 1 1 1.0 1.0 2.5
neighbor 0.3 bin
neigh_modify delay 0 every 20 check no
fix 1 all nve
run 20000
*************** gdb run *****************
(gdb) r -in ../bench/in.lj20000x4
[Thread debugging using libthread_db enabled]
[New Thread 182905599712 (LWP 22206)]
LAMMPS (10 Nov 2005)
Created box = (0 0 0) to (53.3238 53.3238 53.3238)
1 by 1 by 1 processor grid
Created 131072 atoms
Setting up run ...
Memory usage per processor = 43.6951 Mbytes
Step Temperature E_pair E_bond E_total Pressure
0 1.44 -2.9986934 0 -0.83870991 9.8414349
Program received signal SIGSEGV, Segmentation fault.
[Switching to Thread 182905599712 (LWP 22206)]
0x00000000004651e1 in Neighbor::bin_atoms (this=0x6ce500) at neighbor.cpp:1247
1247 bins[i] = binhead[ibin];
(gdb) bt
#0 0x00000000004651e1 in Neighbor::bin_atoms (this=0x6ce500) at
neighbor.cpp:1247
#1 0x0000000000467160 in Neighbor::pair_bin_newton (this=0x6ce500) at
neigh_pair.cpp:274
#2 0x0000000000463abd in Neighbor::build (this=0x6ce500) at neighbor.cpp:715
#3 0x00000000004ab6d1 in Verlet::iterate (this=0x6db2a0, n=20000) at
verlet.cpp:189
#4 0x00000000004ab3e8 in Verlet::run (this=0x6db2a0) at verlet.cpp:105
#5 0x00000000004a0e8d in Run::command (this=0x7fbff7e4f0,
narg=-1765576704, arg=0x6dc650) at run.cpp:34
#6 0x000000000045ce2b in main (argc=3, argv=0x7fbff7e6b8) at style.h:67
(gdb) p mbins
$1 = 85184
(gdb) p nlocal
$2 = 131072
(gdb) p nall
$3 = 175654
(gdb) p i
$4 = 131242
(gdb) p ibin
$5 = 7777472
(gdb) p maxhead
$7 = 85184
(gdb) p *x[i]@3
$10 = {55.287160691799002, 1195.9215653219892, -1151.4360923821766}
(gdb) p bininvx
$13 = 0.71262711641169574
(gdb) p bininvy
$14 = 0.71262711641169574
(gdb) p bininvz
$15 = 0.71262711641169574
(gdb) p nbinx
$16 = 38
(gdb) p nbiny
$17 = 38
(gdb) p nbinz
$18 = 38
**************** Relevant part of the code ***************
void Neighbor::bin_atoms()
int i,ibin,nlocal,nall;
double **x;
nlocal = atom->nlocal;
nall = atom->nlocal + atom->nghost;
x = atom->x;
for (i = 0; i < mbins; i++) binhead[i] = -1;
// bin ghost atoms 1st, so will be at end of linked list
for (i = nlocal; i < nall; i++) {
ibin = coord2bin(x[i]);
bins[i] = binhead[ibin]; <- ********* Line 1247 is here **************
binhead[ibin] = i;
// bin owned atoms
for (i = 0; i < nlocal; i++) {
binhead[ibin] = i;
****************** My makefile **************
[[email protected]... bench]$ cat ../src/MAKE/Makefile.g++
# g++ = RedHat Linux box, g++, MPICH, FFTW
SHELL = /bin/sh
#.IGNORE:
# System-specific settings
CC = g++
#CCFLAGS = -g -O -I/home/sjplimp/tools/mpich/include \
# -I/home/sjplimp/tools/fftw/include \
# -I/home/sjplimp/lammps/poems
CCFLAGS = -g -O -I/opt/mpich-mpd/gnu/lib/include \
-I/home/niels/md/fftw-2.1.5/include \
-I/opt/lam/gnu/include \
-I/opt/gm/include \
-DFFT_FFTW -DGZIP \
DEPFLAGS = -M
LINK = g++
#LINKFLAGS = -g -O -L/home/sjplimp/tools/mpich/lib \
# -L/home/sjplimp/tools/fftw/lib -L/home/sjplimp/lammps/poems
#USRLIB = -lfftw -lmpich -lpoems
LINKFLAGS = -g -O -L/opt/mpich-mpd/gnu/lib \
-L/home/niels/md/fftw-2.1.5/lib\
-L/opt/lam/gnu/lib \
-L/opt/gm/lib \
-Wl,-rpath,/opt/gm/lib
USRLIB = -lfftw -lmpi -llam -llammpio -lpthread -ldl -lgm
SYSLIB =
ARCHIVE = ar
ARFLAGS = -rc
SIZE = size
# Link target
\(EXE\): (OBJ)
\(LINK\) (LINKFLAGS) \(OBJ\) (USRLIB) \(SYSLIB\) \-o (EXE)
\(SIZE\) (EXE)
# Library target
lib: \(OBJ\) (ARCHIVE) \(ARFLAGS\) (EXE) $(OBJ)
# Compilation rules
\.o:.cpp
\(CC\) (CCFLAGS) -c $<
\.d:.cpp
\(CC\) (CCFLAGS) \(DEPFLAGS\) < > $@
# Individual dependencies
DEPENDS = \(OBJ:\.o=\.d\) include (DEPENDS)
