I have an issue concerning drift in the z direction. I’m simulating a box of water with a deform command to keep the xy boundaries fixed at the desired value (b/c I will be eventually placing it on a surface) and NPT with z pressure NULL NULL. I began equilibration wtih NVE (without the deform) and the water-box behaved as expected however when I change to NPT I’m getting the water box moving in the z direction (drifting), I’ve tried various options but haven’t been able to solve the problem, I’m a bit new to the program so any help would be greatly appreciated!! (Below is my input file)
Thanks in advance,
Jennifer
atom_style full
pair_style lj/cut/coul/long 12
bond_style harmonic
angle_style harmonic
dihedral_style none
improper_style none
kspace_style pppm 1e-6
read_data H2O_slab.lammps
neigh_modify delay 5
fix 1 all deform 1 x final 0.0 46.0 y final 0.0 45.0 units box
fix 2 all npt temp 300.0 300.0 100.0 z NULL NULL 1000 tchain 10 pchain 10
fix 3 all momentum 1000 linear 1 1 1 angular
thermo_style custom step temp pe ke etotal lx ly lz vol
thermo 10
timestep 1
dump 2 all custom 100 dump.lammpstrj id type xs ys zs
restart 10000 H2O_slab
run 20000
