I’m working on simulating a nanodiamond molecule using the AIREBO potential. My input file is given below -
atom_style molecular
pair_style airebo 3.0 1 1
read_data nanodiamonds.txt
pair_coeff * * …/potentials/CH.airebo C
fix 2 all nve
velocity all create 298.0 9999999989
fix 1 all temp/rescale 1 298.0 298.0 1 1
timestep 0.0001
thermo_style custom step temp press etotal pe epair
thermo 100
run 10000
unfix 1
timestep 0.0001
thermo 100
dump 1 all custom 50 dump.nano id type x y z vx vy vz
run 10000
The data file ‘nanodiamonds.txt’ contains only the initial starting positions of the atoms in the nanodiamond molecule. The molecule does not properly equilibrate, that is the total energy does not reach a stable value. I was wondering if my input file was correct and if there is anything I can do other than increasing the timesteps for equilibration and changing the length of the timestep.
Thanks for the help.
-Ferdaus
