Hi Steve
Thanks for your quick reply. Can I just check what outputs will be affected with the use of the hybrid with TIP4P? Is it only the computation of the viral pressure?
If I were to use the TIP4P hybrid with the AIREBO potential, with NVE simulation and temperature control (i.e. a non pressure-control simulation), would the forces and other outputs be computed correctly?
Huck Beng
