I am applying two tensile tests to my system. I introduce total of 6% (approx.)expansion in both runs. But one ends with a segmentation fault where I am trying to increase the x-dimension by 2% between 10ps intervals and I repeat it 3 times in order to give 6% expansion. I wonder what is causing this.
the input that runs fine is below:
units real
atom_style molecular
read_restart npt.data
temperature temper all full units box
neighbor 1.0 bin
neigh_modify delay 10 check yes
thermo 100
total of 6% expansion in ±x direction
target x dimensions are adjusted accordingly
fix 1 all volume/rescale 100 x -5.2607 62.0607
fix 2 all npt 300.15 300.15 50 aniso NULL NULL 1.0 1.0 1.0 1.0 1000
timestep 1
dump 1 all custom 1000 stress.bin sxx syy szz
dump 2 all custom 10000 atoms.* x y z
run 20000
write_restart strain.20ps
The input that gives segmentation fault is below:
units real
neighbor 1.0 bin
thermo 100
fix 1 all volume/rescale 1000 x -3.9905 60.1554
timestep 1
dump 1 all custom 1000 stress2.bin sxx syy szz
run 2000
unfix 1
run 10000
fix 1 all volume/rescale 1000 x -4.6383 61.4383
run 2000
unfix 1
run 10000
fix 1 all volume/rescale 1000 x -5.299 62.099
run 2000
unfix 1
run 10000
write_restart strain2.36ps
the second input runs up to the second fix volume/rescale than stops. Can it be something to do with x dimensions that I define? I manually calculate them to enter in input but precision may not match with what the computer calculates from previous fix. What can I do about this?
When I did the similar test first with fix uniaxial, it did not work with npt. And when I use NVE, after the first fix uniaxial, initial and target strains become same for all of the following deformations.
Initial strain = 1.001 0.9995 0.9995
Target strain = 1.001 0.9995 0.9995
input script:
fix 1 all nve
applying strain of 0.1% for the first time
fix 2 all uniaxial 500 x 1.001
run 1000
unfix 2
dump …
run 5000
undump 1
applying strain of 0.1% for the 2nd time
fix 3 all uniaxial 500 x 1.001
run 1000
unfix 3
dump …
run 5000
undump 2
…goes like this. since I am not comfortable with uniaxial and it wants to keep volume constant, I prefered volume/rescale with P constraints only in x.
Thank you for taking the time to read this long mail, I would appreciate for you suggestions.
Burcu
