i’m interesting in studying a de-wetting problem. The liquid that de-wets and the substrate
that supports it interact via a LJ potential.
As an initial step in this simulation, one needs to create a liquid-film. To do so, it’s usual
to “sandwich” the film between two repulsive walls (i.e. walls that interact with the liquid
by means of the repulsive part of the LJ only). Subsequently, the attractive is switch on
and de-wetting starts. Also, by being able to control the attractive and repulsive part of
the LJ potential, one can see how changing the interactions changes the de-wetting.
To do the above, the LJ potential must look like this:
U=4epsilon(Crepulsive-D*attractive).
The LJ potential in lammps has a generic form, which in turn does not allow to switch
on-off the components of the LJ potential.
Is this so? And if so, is there a way one can use within lammps to switch off the attractive
part of the LJ potential?
Miguel
