[lammps-users] Tabular potential for bond_style
I am using “lammps-29Sep10” windows binary executable to test the use of tabular potentials.
when I followed the manual and created the potential file for a simple harmonic function for two atom model.
I am getting unusual errors as given.
Step Temp E_pair E_mol TotEng Press 0 0 0 -1.#IND -1.#IND -1.#IND **I could not figure out want went wrong.** **Your help is greatly appreciated.**
The details are give below the files (a) in.test (b) test.lammps © potential tabular file (d) output
(a) in.test file
units real
atom_style full
bond_style table linear 10000
atom_modify sort values 1.0
read_data test.lammps
neighbor 2.0 bin
neigh_modify delay 5
timestep 1.0
min_style cg
min_modify dmax 0.2
minimize 1.0e-4 1.0e-6 10000 100000
thermo 100
thermo_style custom step temp vol press ke pe etotal pxy pxz pyz
fix 1 all nvt temp 293.0 293.0 100.0
dump 1 all atom 2000 dump.lammpstrj
run 25000
(b) test.lammps file
2 atoms
1 bonds
0 angles
0 dihedrals
0 impropers
1 atom types
1 bond types
0 angle types
0 dihedral types
0 improper types
0.0 5.0 xlo xhi
0.0 5.0 ylo yhi
0.0 5.0 zlo zhi
Masses
1 15.0
Bond Coeffs
1 bond.table bond
Atoms
1 1 1 0.0000 1.00 5.00 4.00
2 1 1 0.0000 2.00 5.00 4.00
Bonds
1 1 1 2
creating the table in Matlab
r=0:1e-3:10.0;
U = 0.5 * 899.95759 * (r-1.54).^2;
F = - 0.5 * 899.95759 * 2 * (r-1.54);
gives the table
© bond.table
bond Potential for butane
bond_butane
N 10001
1.0000000e+000 0.0000000e+000 1.0671697e+003 1.3859347e+003
2.0000000e+000 1.0000000e-003 1.0657842e+003 1.3850347e+003
9.9980000e+003 9.9970000e+000 3.2182865e+004 -7.6109413e+003
9.9990000e+003 9.9980000e+000 3.2190477e+004 -7.6118413e+003
1.0000000e+004 9.9990000e+000 3.2198089e+004 -7.6127413e+003
1.0001000e+004 1.0000000e+001 3.2205702e+004 -7.6136412e+003
(d) When I run (output)
Scanning data file …
1 = max bonds/atom
Reading data file …
orthogonal box = (0 0 0) to (5 5 5)
1 by 1 by 1 processor grid
2 atoms
1 bonds
Finding 1-2 1-3 1-4 neighbors …
1 = max # of 1-2 neighbors
0 = max # of 1-3 neighbors
0 = max # of 1-4 neighbors
1 = max # of special neighbors
WARNING: Resetting reneighboring criteria during minimization
Setting up minimization …
Memory usage per processor = 2.09904 Mbytes
srinivas
Someone (you, your collaborator?) just sent me a small code
change for bond_table so it can read CR-line-end files
like the bond_style table command reads in, presumably created on a Windows box.
It was just part of
another 25Oct10 patch, so you can try it out, and see
if it fixes your problem.
Or you could just install Linux and remove Windows from
your box, and life will be better in many, many ways :slight_smile:
