2010/7/12 <[email protected]...>:
Thanks, Axel
What you mean NVE should be NVE without any thermal control, correct? It is
a good choice, but it still need a starting configuration and velocity
profile of the atoms, which is corresponding to a initial temperature value.
everything is allowed in love, war and setting up your system.
Besides, The goal of my current simulation is to study the effect of
temperature(thermal ) on the reorientation and diffusion of the C60 under 1D
confinement, thus, NVE without thermal control is not suitable. In my
opinion, the thermostat is just a modification method on the velocity of
i disagree with this statement. a thermostat is modeling the coupling
to a larger reservoir of degrees of freedom. for your system, this
doesn't exist, at least not for the C60. i would not want to do any
thermalization
on it, as its only coupling with the "outside world" is the direct
interaction with
the CNT, and that you have represented explicitly. any thermostat would
add unphysical changes to the C60 trajectory in my opinion.
now the CNT is a different story. it could be coupled to the matrix it is
embedded in and thus thermalization could be justified. but i would make
it a very, very weak thermostat (i.e. use a very long time constant, only
large enough to remove the drift in total energy from numerical inaccuracies
during time integration).
atoms, regardless of the model size, it should be the same as the
temp/rescale. Now, what I am using now is NVE+(temp/berendsen on CNT and C60
respectively), but I do not know whether it is OK.
applying thermostats to "free" particles can have lots of undesireable
or unexpected effects on your results. you want to avoid temp/rescale
at all costs, as this gives your system an unphysical "kick" at every
rescale. generally, any method based on velocity rescaling (i.e. also
a berendsen thermostat) has the downside of emphasizing any existing
collective motion (normal mode) and thus adding unwanted bias
to your phase space sampling. taking about sampling, often a setup
with a "massive thermostat" (i.e. one thermostat per degree of freedom)
is used in these cases to improve ergodicity, but one has to be aware
that it will also affect (dampen) the magnitude of fluctuations in the
kinetic energy (so the opposite of a global rescaling temperature control).
finally, for a small system like yours, sampling is fairly easy to achieve
with a classical model, but you will have to compensate for the unavoidable
drift in total energy due to the numerical integration of the equations of
motion.
this is why short of having a massive nose-hoover thermostat available
to me the choice of a langevin thermostat, but with a very long time constant
(and thus minimal bias) and only applied to the CNT would appear to be
the best choice.
cheers,
