[lammps-users] Tersoff &stress/atom
hi,
I am trying to use Tersoff potential for a simulation. The documentation
for Tersoff in the LAMMPS manual (manual dated 22 Jan, 2008) says that it
doesnt support stress/atom, energy/atom calculations. (pg 427) while at
the same time, the restrictions section in the documentation for compute
stress/atom command (pg 147) lists only airebo, meam and TIP4P as styles
which doesnt support it.
Is there an inconsistency? Can any one clarify?
Also, i am a bit confused about the units. I am using metal style units
in my simulation. Can anyone confirm the unit of the numbers computed
using compute stress/atom command. As far as i understand it should be in
eV for metal style.
Thanks in advance,
Sincerely,
Nithin Mathew
CII 2033,
SCOREC,
RPI
Nithin,
Please see the 23 Jan 2008 bug fix:
"Updated the doc pages for the various pair styles to reflect that all
of them can now tally per-atom energy and stress so that they can be
used with the compute pe/atom and compute stress/atom commands."
eV for metal style.
Please see:
especially:
"Note that as defined in the formula, per-atom stress is the negative
of the per-atom pressure tensor. It is also really a stress-volume
formulation, meaning the computed quantity is in units of
pressure-volume. It would need to be divided by a per-atom volume to
have units of stress (pressure), but an individual atom's volume is
not easy to compute in a deformed solid or a liquid. Thus, if the
diagonal components of the per-atom stress tensor are summed for all
atoms in the system and the sum is divided by 3V, where V is the
volume of the system, the result should be -P, where P is the total
pressure of the system. "
Also see:
specifically:
"For style metal, these are the units:
distance = Angstroms
time = picoseconds
mass = grams/mole
energy = eV
velocity = Angstroms/picosecond
force = eV/Angstrom
temperature = degrees K
pressure = bars
charge = multiple of electron charge (+1.0 is a proton)
dipole = charge*Angstroms
electric field = volts/Angstrom "
So pressure-volume units for style metal are bars*angs^3.
Paul
