Dear Axel
Thanks for the quick response.
My version is LAMMPS (20 Nov 2019).
For this simple setup, the two results are different by roughly 10 percent.
Regarding the system that I actually working with, the different is much larger.
Below I write down the input file and the output data.
The input file is following:
log LOG.0
shell “echo 0 $(date +%d-%b-%Y-%T) START >> JOBINFO”
units lj
boundary p p s
atom_style bond
CREATE INITIAL SYSTEM
lattice sc 1.0
region REGION block -0.5 7.500000000000e+00 -0.5 7.500000000000e+00 0 6
create_box 2 REGION bond/types 2 extra/bond/per/atom 18
create_atoms 1 box
variable layer atom “floor((z+0.001))”
FROZEN group: bottom layer
variable tmp atom v_layer==0
group FROZEN variable tmp
variable tmp delete
bond_style harmonic
SET LAMMPS RUNTIME LIMIT: clean exit after RUNTIME hours
timer timeout 23:00:00 every 10000
mass / md timestep
mass * 1.0
timestep 0.001
SET INTERACTIONS
pair_style hybrid lj/smooth/linear 3
pair_coeff * * none
pair_coeff * * lj/smooth/linear 0 1
comm_modify vel yes
neigh_modify every 10 delay 0 check yes
REPLACE BOND PARAMETERS WITH DESIRED ONES (!)
bond_coeff 1 10 1
bond_coeff 2 10 1.414213562373e+00
group SUB type 1 2
create_bonds many SUB SUB 1 9.900000000000e-01 1.010000000000e+00
create_bonds many SUB SUB 2 1.404213562373e+00 1.424213562373e+00
MD group: everything excluding bottom layer and beads
group MD subtract SUB FROZEN
INITIAL CONDITIONS / ASSIGN VARIABLES AND COMPUTES
assign initial velocities to substrate particles, remove any com motion / global rotation
velocity MD create 0.15 18618316 mom yes rot yes
fix MD MD nve
temperature of the MD group (standard ‘temp’ is too low, since this includes frozen particles)
compute MDTEMP MD temp
compute peratom MD pe/atom
compute pe all reduce sum c_peratom
write_data init.0
thermo 500
thermo_style custom step temp c_MDTEMP c_pe
thermo_modify norm no
run 5000
#write_data equil.0
PRODUCTION STAGE
run 100000
shell “echo 0 $(date +%d-%b-%Y-%T) FINISH >> JOBINFO”
quit
The corresponding output is (when setting the number of type = 2)
Step Temp c_MDTEMP c_pe
5000 0.067266531 0.078506892 40.152896
5500 0.067288419 0.078532437 39.913958
6000 0.066552635 0.077673702 40.45838
6500 0.069867469 0.081542451 38.228388
7000 0.070450536 0.082222949 37.884144
7500 0.068635944 0.080105136 39.053247
8000 0.067865416 0.079205851 39.781417
8500 0.07022641 0.081961371 38.002604
9000 0.068169544 0.0795608 39.397138
9500 0.068233379 0.079635301 39.403529
10000 0.070104774 0.081819409 38.194574
10500 0.0664537 0.077558234 40.321111
11000 0.069345706 0.0809335 38.531507
11500 0.067488085 0.078765467 40.137109
12000 0.070170954 0.081896649 38.187992
12500 0.069187902 0.080749326 39.085835
13000 0.069911441 0.08159377 38.623282
13500 0.071996657 0.08402743 37.099154
14000 0.073405097 0.085671223 36.223269
14500 0.071799285 0.083797077 37.312354
15000 0.076258406 0.089001325 34.49032
15500 0.071472916 0.08341617 37.257779
16000 0.072022699 0.084057823 36.857586
16500 0.071846726 0.083852446 37.003052
17000 0.067509739 0.078790739 39.740275
17500 0.071276402 0.083186819 37.311916
18000 0.071823357 0.083825171 37.313524
18500 0.073082271 0.085294452 36.207564
19000 0.073069549 0.085279605 36.153013
19500 0.072553933 0.084677828 36.606639
20000 0.071916984 0.083934444 36.781882
20500 0.072994523 0.085192041 36.31569
21000 0.072256629 0.084330843 36.784576
21500 0.074921674 0.087441222 35.13166
And when setting the number of type = 1
5000 0.073304528 0.085553849 35.931852
5500 0.060067827 0.070105271 44.717848
6000 0.065163119 0.076051995 41.547947
6500 0.068057504 0.079430037 39.616606
7000 0.056450572 0.065883565 46.982729
7500 0.064316954 0.075064434 41.808312
8000 0.061735318 0.072051403 43.832576
8500 0.065540897 0.076492901 41.077493
9000 0.071118584 0.083002629 37.581507
9500 0.066207165 0.077270503 40.380476
10000 0.060717219 0.070863177 44.238874
10500 0.060347656 0.07043186 44.20803
11000 0.064025711 0.074724524 42.269167
11500 0.064187221 0.074913023 41.862736
12000 0.063765906 0.074421305 42.115145
12500 0.061483035 0.071756962 43.972857
13000 0.05863742 0.06843584 45.711041
13500 0.060020829 0.070050419 44.864965
14000 0.06643381 0.077535021 40.622482
14500 0.052738521 0.061551225 49.589298
15000 0.061248188 0.071482872 43.980723
15500 0.064726856 0.075542831 41.323342
16000 0.065004547 0.075866926 41.211363
16500 0.061268131 0.071506148 43.726626
17000 0.063068894 0.073607821 42.827017
17500 0.063384651 0.073976342 42.397989
18000 0.064769322 0.075592394 41.456778
18500 0.059161239 0.06904719 45.299969
19000 0.060616103 0.070745165 44.432415
19500 0.059887791 0.06989515 44.743213
20000 0.069074152 0.080616568 38.822442
20500 0.065382365 0.076307877 41.210434
21000 0.067379641 0.078638902 39.954273
21500 0.061553908 0.071839678 43.702575
Please look at c_pe which is roughly 10% higher for the latter case.
Miru
