Dear all:
I do not know the meaning of the parameters of style and coord in fix wall/lj126 command
The original is :
style = xlo or xhi or ylo or yhi or zlo or zhi
coord = position of wall
Whether the xlo and xhi means a wall parallel to x surface? What is the difference between xlo and xhi?
What is the meaning of coord?
Could anybody give me some examples?
Thanks in advance.
Kitty:
The “coord” parameter specifies the location of the wall. Think of it as an equation of the form z = coord (or x = coord or y = coord) which expresses the position of the wall.
The difference between xlo and xhi (for instance) is which side you’re blocking off. “zlo” means that the wall is below z = coord, while “zhi” mens the wall is above z = coord. (The same obviously holds for x and y.)
–AEI
