Hello All,
I am using the 27 May 2021 version. I am currently running a simulation with a model of graphite immersed in water. The image is the initial state of my model. When I set the pair interaction between water and graphite as 0 it runs smoothly. However, this is not the case I want so I also set pair interaction between them. The problem is that after I adjusted the pair coefficient the simulation was stuck. No error was reported but no output either. Could someone give me some hints on resolving it?
Great thanks
Below is the relevant input script.
------------------------ INITIALIZATION ----------------------------
atom_style full
bond_style harmonic
angle_style harmonic
----------------------- ATOM DEFINITION ----------------------------
read_data H2O4.data extra/atom/types 1
read_data GCOOR.data add append offset 2 0 0 0 0
------------------------ FORCE FIELDS ------------------------------
pair_style hybrid lj/cut 10.0 lj/cut/coul/cut 9.0 9.0 tersoff
pair_coeff 1 1 lj/cut/coul/cut 0.0016 3.166
pair_coeff 1 2 lj/cut/coul/cut 0 0
pair_coeff 2 2 lj/cut/coul/cut 0 0
pair_coeff 1 3 lj/cut 0.004 3.19
pair_coeff 2 3 lj/cut 0 0
pair_coeff * * tersoff C.tersoff NULL NULL C
info coeffs
#------------------------- Bond and Angle Setting ------------------------------
bond_coeff 1 0 1.0
angle_coeff 1 0 109.47
------------------------- SETTINGS ---------------------------------
set group
group H2O id 1:3861
group Gra id 3862:4401
compute peratom all pe/atom
compute temp H2O temp
