Hi,all
I am using lammps to model the amorphous structure of organic molecules. I applied NVT and NPT on the system, but the molecule structure seems to be distorted too much after running, which is no realistic compared to experimental experience. So i wonder is there any way to fix the shape of the molecules, to some degree, while running MD?
Thanks!
Xiao
Hi,all
I am using lammps to model the amorphous structure of organic molecules\.
what you describe sounds like you have wrong
force field parameters, or are missing bond, angle,
dihedral or improper definitions.
