I noticed that if I have:
thermo_modify norm yes
thermo_style custom step temp pe etotal press
the second command resets values set by thermo_modify, and in this
example values are not normalized.
Is this intentional?
Marcin
Marcin
Marcin,
I fell for the same "trap", so I can certainly empathize with you. But
it is intentional. When you issue the thermo_style command, you
create new computes that are initialized to their default values. I'd
recommend switching the order of your commands like this:
Paul
Thanks for the reply, Paul.
Yes, I know the sequence in that order works, my question was just out
of curiosity.
Marcin
