I am using LAMMPS version lammps-30Nov05.
My objective is to 'thermalize' a system composed soley of TIP3P water
molecules at 300 K and 1 atmosphere. My LAMMPS input file
contains the following relevant lines:
units real
timestep 2.0
thermo 5000
fix 3 all npt 300.0 300.0 100.0 xyz 1.0 1.0 200.0
The log file for the corresponding portion of the simulation contains
the following lines:
Step Temp E_pair E_mol TotEng Press Volume
50000 300.26691 -16453.569 2606.2144 -11163.155 765.16096
23163.727
55000 302.22421 -16345.575 2576.9987 -11066.88 3027.7438
23265.413
60000 298.2265 -16717.18 2669.2943 -11381.927 -2068.6822
23385.803
65000 293.63985 -16647.839 2801.2188 -11221.663 354.33068
23387.336
70000 304.61083 -16512.807 2727.571 -11062.204 2051.8615
23445.992
75000 296.91324 -16832.354 2689.7354 -11488.399 -2164.4052
23561.782
Because the units are real, my 'fix npt' pressure units are in
atmospheres. I then assumed that the 'thermo' output pressure units
are also atmospheres, If so, the system pressure is fluctating by
thousands of atmospheres, both plus and minus. This seems excessive
to me. (I reduced timestep to 1.0, and obtained (qualitatively) the
same results.)
Am I making an obvious mistake somewhere?
Ken.
