LAMMPS folks,
I am trying to judge the limits of the range of applicability of water potentials found in the literature. However, I am having trouble using certain combinations of thermostats and barostats cited in these papers. I am using water that was first equilibrated by the NPT thermostat. Could someone please tell me why they are failing?
The error is reported in the thermo output:
Step Temp peperh2o Press density
190000 249.77017 -12.826013 130.91496 0.89062524
190001 298 -12.310568 1100.8691 0.89062524
190002 298 nan nan 0.89062524
ERROR: Computed temperature for fix temp/rescale cannot be 0.0
BEGIN INPUT FILE:
units real
atom_style full
read_restart 298K.1Bar.restart.190000
read_data Ice40.dat
## alternate way to set charges - beside manually in file ###
group ox type 2
group hy type 1
set group ox charge -0.8476
set group hy charge 0.4238
### Flexible SPC/E Potential Parameters ###
### Zhang et al., Fluid Phase Equilibria, 262 (2007) 210-216 ###
pair_style lj/cut/coul/cut 15.5
pair_modify tail yes #long range correction to lj
pair_coeff 2 2 0.1502629 3.1169
pair_coeff 1 2 0.0341116368 2.04845
pair_coeff 1 1 0.00774378 0.98
bond_style harmonic
bond_coeff 1 176.864 0.9611
angle_style harmonic
angle_coeff 1 42.1845 109.4712
#the order of the ensemble and thermostat/barostat commands might be important!
fix ensemble all nve
fix ptherm all press/berendsen iso 1.0 1.0 1000.0
fix ttherm all temp/rescale 1 298.0 298.0 0.01 1.0
compute
compute totalpe all pe
#Variables
variable peperh2o equal c_totalpe/count(ox) #total energy per H2O molecule
variable tempv equal vol
variable v equal ${tempv}
variable density equal count(ox)/v_v*29.91526 #density of water
#Computes
v_keperO file ave.spc.dat
compute myRDF all rdf 500 1 1 1 2 2 2
fix 3 all ave/time 2 100 5000 c_myRDF file zhang.rdf mode vector
neighbor 2.0 bin
neigh_modify delay 0 every 10 check yes
thermo_modify norm no flush yes press ptherm_press temp ttherm_temp #order of press & temp call is very important
thermo_style custom step temp v_peperh2o press v_density
thermo 1
#dumps
dump waterdump all atom 5000 298K.1Bar.dump
restart 10000 298K.1Bar.restart
#run variables
timestep 0.75
run 200000
