Dear lammps users,
I use tip4p and fix shake for my water molecules in desalination but they resist piston pressure (350-500 bar). Water molecules shrink from their original state and behave abnormally. The input script is given below:
atom_style full
timestep 0.00005
Atom Definition
read_data membrane.data
group fluid1 id 801:9880
group fluid2 id 10387:11286
group fluid union fluid1 fluid2
group Cg type 1
group Cl type 2
group H type 3
group N type 4
group Na type 5
group O type 6
group S type 7
group Hw type 8
group Ow type 9
group Cm type 10
group H2O union Hw Ow
group salt union Cl Na
group membrane union H N O S Cm
variable zpiston1 equal -130
variable zmembrane equal 0
variable zpiston2 equal 130
variable zmin1 equal {zpiston1}-1.0
variable zmax1 equal {zpiston1}+1.0
region piston1zone block INF INF INF INF {zmin1} {zmax1} units box
variable zmin3 equal {zpiston2}-1.0
variable zmax3 equal {zpiston2}+1.0
region piston2zone block INF INF INF INF {zmin3} {zmax3} units box
group piston1 region piston1zone
group piston2 region piston2zone
group piston union piston1 piston2
group thermostat_target union H2O salt membrane piston1 piston2
set group Cl charge -1
set group Na charge 1
set group Hw charge 0.5242
set group Ow charge -1.0484
set group Cg charge 0
Interatomic Potential
pair_style hybrid lj/cut/tip4p/long 9 8 7 16 0.1546 12 12 airebo 3.0 0 1
pair_modify tail yes
pair_coeff * * airebo CH.airebo C NULL NULL NULL NULL NULL NULL NULL NULL NULL
kspace_style pppm/tip4p 1.0e-4
pair_coeff 2 2 lj/cut/tip4p/long 0.01322 3.48
pair_coeff 3 3 lj/cut/tip4p/long 0.00043 2.85
pair_coeff 4 4 lj/cut/tip4p/long 0.01799 3.56
pair_coeff 5 5 lj/cut/tip4p/long 0.02168 2.80
pair_coeff 6 6 lj/cut/tip4p/long 0.01799 3.30
pair_coeff 7 7 lj/cut/tip4p/long 0.01322 3.77
pair_coeff 8 8 lj/cut/tip4p/long 0.00000 0.0
pair_coeff 9 9 lj/cut/tip4p/long 0.00803 2.81
pair_coeff 10 10 lj/cut/tip4p/long 0.01322 3.72
pair_coeff 1 2 lj/cut/tip4p/long 0.01322 3.60
pair_coeff 1 3 lj/cut/tip4p/long 0.00239 3.28
pair_coeff 1 4 lj/cut/tip4p/long 0.01542 3.64
pair_coeff 1 5 lj/cut/tip4p/long 0.01693 3.26
pair_coeff 1 6 lj/cut/tip4p/long 0.01542 3.51
pair_coeff 1 7 lj/cut/tip4p/long 0.01322 3.75
pair_coeff 1 8 lj/cut/tip4p/long 0.00000 1.86
pair_coeff 1 9 lj/cut/tip4p/long 0.01030 3.27
pair_coeff 1 10 lj/cut/tip4p/long 0.01322 3.72
pair_coeff 2 3 lj/cut/tip4p/long 0.00239 3.17
pair_coeff 2 4 lj/cut/tip4p/long 0.01542 3.52
pair_coeff 2 5 lj/cut/tip4p/long 0.01693 3.14
pair_coeff 2 6 lj/cut/tip4p/long 0.01542 3.39
pair_coeff 2 7 lj/cut/tip4p/long 0.01322 3.63
pair_coeff 2 8 lj/cut/tip4p/long 0.00000 1.74
pair_coeff 2 9 lj/cut/tip4p/long 0.01030 3.15
pair_coeff 2 10 lj/cut/tip4p/long 0.01322 3.60
pair_coeff 3 4 lj/cut/tip4p/long 0.00279 3.20
pair_coeff 3 5 lj/cut/tip4p/long 0.00306 2.82
pair_coeff 3 6 lj/cut/tip4p/long 0.00279 3.07
pair_coeff 3 7 lj/cut/tip4p/long 0.00239 3.31
pair_coeff 3 8 lj/cut/tip4p/long 0.00000 1.42
pair_coeff 3 9 lj/cut/tip4p/long 0.00186 2.83
pair_coeff 3 10 lj/cut/tip4p/long 0.00239 3.28
pair_coeff 4 5 lj/cut/tip4p/long 0.01975 3.18
pair_coeff 4 6 lj/cut/tip4p/long 0.01799 3.43
pair_coeff 4 7 lj/cut/tip4p/long 0.01542 3.66
pair_coeff 4 8 lj/cut/tip4p/long 0.00000 1.78
pair_coeff 4 9 lj/cut/tip4p/long 0.01202 3.18
pair_coeff 4 10 lj/cut/tip4p/long 0.01542 3.64
pair_coeff 5 6 lj/cut/tip4p/long 0.01319 3.05
pair_coeff 5 7 lj/cut/tip4p/long 0.01693 3.29
pair_coeff 5 8 lj/cut/tip4p/long 0.00000 3.26
pair_coeff 5 9 lj/cut/tip4p/long 0.01319 2.80
pair_coeff 5 10 lj/cut/tip4p/long 0.01693 3.26
pair_coeff 6 7 lj/cut/tip4p/long 0.01542 3.54
pair_coeff 6 8 lj/cut/tip4p/long 0.00000 1.65
pair_coeff 6 9 lj/cut/tip4p/long 0.01202 3.06
pair_coeff 6 10 lj/cut/tip4p/long 0.01542 3.51
pair_coeff 7 8 lj/cut/tip4p/long 0.00000 1.88
pair_coeff 7 9 lj/cut/tip4p/long 0.01030 3.29
pair_coeff 7 10 lj/cut/tip4p/long 0.01322 3.75
pair_coeff 8 9 lj/cut/tip4p/long 0.00000 1.40
pair_coeff 8 10 lj/cut/tip4p/long 0.00000 1.86
pair_coeff 9 10 lj/cut/tip4p/long 0.01030 3.27
bond_style harmonic
bond_coeff 1 15.177 1.530
bond_coeff 2 15.177 1.090
bond_coeff 3 15.177 1.462
bond_coeff 4 15.177 1.420
bond_coeff 5 15.177 1.800
bond_coeff 6 15.177 1.022
bond_coeff 7 15.177 0.980
bond_coeff 8 15.177 1.394
angle_style harmonic
angle_coeff 1 2.168 109.471
angle_coeff 2 2.168 109.471
angle_coeff 3 2.168 109.471
angle_coeff 4 2.168 109.471
angle_coeff 5 2.168 109.471
angle_coeff 6 2.168 106.700
angle_coeff 7 2.168 106.700
angle_coeff 8 2.168 104.510
angle_coeff 9 2.168 92.1000
angle_coeff 10 2.168 109.471
angle_coeff 11 2.168 109.471
angle_coeff 12 2.168 109.471
angle_coeff 13 2.168 109.471
angle_coeff 14 2.168 106.700
angle_coeff 15 2.168 106.700
angle_coeff 16 2.168 104.510
angle_coeff 17 2.168 109.471
dihedral_style harmonic
dihedral_coeff 1 0.9756 -1 2
dihedral_coeff 2 0.9756 -1 2
dihedral_coeff 3 0.9756 -1 2
dihedral_coeff 4 0.9756 -1 2
dihedral_coeff 5 0.9756 -1 2
dihedral_coeff 6 0.02168 -1 6
dihedral_coeff 7 0.02168 -1 6
dihedral_coeff 8 0.00000 -1 6
dihedral_coeff 9 0.00000 -1 3
dihedral_coeff 10 0.0433 -1 3
dihedral_coeff 11 0.0433 -1 3
dihedral_coeff 12 0.9756 -1 2
dihedral_coeff 13 0.9756 -1 2
dihedral_coeff 14 0.9756 -1 2
dihedral_coeff 15 0.9756 -1 2
dihedral_coeff 16 0.02168 -1 6
dihedral_coeff 17 0.02168 -1 6
dihedral_coeff 18 0.00000 -1 6
dihedral_coeff 19 0.00000 -1 6
dihedral_coeff 20 0.04336 -1 3
dihedral_coeff 21 0.9756 -1 2
dihedral_coeff 22 0.9756 -1 2
dihedral_coeff 23 0.9756 -1 2
dihedral_coeff 24 0.9756 -1 2
dihedral_coeff 25 0.02168 -1 6
dihedral_coeff 26 0.02168 -1 6
velocity fluid create 300.0 1929457 rot yes dist gaussian
neighbor 2.0 bin
neigh_modify every 1 delay 0 check yes page 500000 one 50000
fix pistonfreeze piston setforce 0.0 0.0 0.0
fix membranefreeze membrane spring/self 1000
compute selective_thermostat thermostat_target temp
thermo_modify temp selective_thermostat
thermo_style one
thermo 10
run 0
minimize 1.0e-4 1.0e-6 1000 1000
fix relax all box/relax x 0.0 y 0.0
minimize 1.0e-4 1.0e-6 100 1000
unfix relax
unfix pistonfreeze
fix pistonkeep piston setforce 0.0 0.0 NULL
fix piston1thrust piston1 aveforce NULL NULL 0.0005
fix piston2thrust piston2 aveforce NULL NULL -0.0005
fix 1 fluid shake 1.0e-4 100 0 b 7 a 16
fix NVTequilib thermostat_target nvt temp 300 300 0.05
timestep 0.0005
thermo 1000
dump 1 all xyz 1000 dump1.xyz
run 100000
unfix NVTequilib
unfix piston1thrust
unfix piston2thrust
reset_timestep 0
timestep 0.0005
fix piston1push piston1 aveforce NULL NULL 0.000769
fix piston2push piston2 aveforce NULL NULL -0.0000015
fix NVT thermostat_target nvt temp 300 300 0.05
region W block -200 200 -200 200 1 200 units box
region Q block -200 200 -200 200 -200 -1 units box
group Water1 dynamic H2O region W
group Water2 dynamic H2O region Q
group Ion dynamic salt region W
variable Water1Number equal count(Water1)
variable IonNumber equal count(Ion)
variable Water2Number equal count(Water2)
