Hi
I defined the variable delt with :
variable delt equal 1.01
and I define displace box with:
displace_box all x scale v_delt y scale v_delt units box
then when I run the script it gives error like
ERROR: Cannot use neighbor bins - box size << cutoff
and also tried to print the variable to check if it is assigned the correct value
it also did not work.
sincerely.
dundar
