Steve,
In thermal conductivity calculation using fix heat command, the velocites are scaled at each timestep. I want to output the velocity scaling factor at each timestep. Is there any way i can do this??
Ajit
Steve,
Ajit
The quantity could be stored and made available for output by the fix. Talk
to Paul, as he wrote the fix, and see if he wants to add it.
I've added the suggested feature to the source code and documentation in the repository. The changes will be reflected in the next patch.
Paul
