I have a difficulty on establishing water only modeling by using lammps. Note that I just started to use lammps.
I started to write up the codes as you can see below, but error message showed up while I am trying to run this. Could you check this out how I improve my code?
Thank you in advance.
tip3 water simulation
units real
atom_style full
neighbor 10 bin
neigh_modify delay 5
read in atom coord, bonds, angles --also box size,masses
You can't create molecules with create_atoms, since there is
no way to specify the bond topology. You'll need to create
a data file that has the molecules in it and use read_data.
I am new user of Lammps. I recently installed upgraded version. The
strange thing is that I couldn't run code with minimization. If I comment
the minimization line in the input file, it works fine, but with
minimization, I got core dupmed error. But the version of July20 works fine.
Anyone could help to figure out what might be the problem?
The input file, data file and force field are attached in this email.
This was a bug with using the SW potential in hybrid mode. When
we changed the way pair hybrid is done in the latest release, all the
pair potential files changed slightly, and the SW one did not get
changed correctly.
thanks for the patch for the hybrid sw. It works fine if we compile serial, but still crashes for the parallel version.
The version of July 20th works well both.
The problem seems to be general for hybrid in the new release. It crashes with hybrid sw morse and
hybrid lj/cut morse too.
I can run the script you posted originally (in.test, data, etc)
fine in parallel with the current (fully patched) version. Can you be more
specific about what script is crashing and how?
