Hi, Axel
I am still confused about what happened in fix smd. You said:
consider that you have a spring and a (strong) wire. the length
of the wire is R0. your group is connected to this wire and the
spring which is then connected to your reference point. the wire
always keeps the moving part of the spring at a distance of R0
from your group. this makes sense for fix spring, but not in
steered MD.
When R0 is set to be zero, the model is simplified like this:
sio2---spring---ref.point
>______________|
R
Now I use constant velocity mode, set velocity to be 1.0. Which end of
the spring is moving, sio2 end or ref.point end?
#logout:
LAMMPS (18 Apr 2010)
# Created by charmm2lammps v1.8.1 on Sun Apr 4 20:05:41 CST 2010
units real
neigh_modify delay 2 every 1
atom_style full
bond_style harmonic
angle_style charmm
dihedral_style charmm
improper_style harmonic
pair_style lj/charmm/coul/charmm 8 10
pair_modify mix arithmetic
#kspace_style pppm 1e-4
read_data data.test
Scanning data file ...
4 = max bonds/atom
6 = max angles/atom
18 = max dihedrals/atom
1 = max impropers/atom
Reading data file ...
orthogonal box = (-24 -24 -33.6931) to (24 24 83.5)
1 by 1 by 1 processor grid
27324 atoms
27324 velocities
21428 bonds
24562 angles
31944 dihedrals
144 impropers
4 = max # of 1-2 neighbors
12 = max # of 1-3 neighbors
16 = max # of 1-4 neighbors
20 = max # of special neighbors
special_bonds charmm
#define groups
group sio2 type 17 18 19 20 21
354 atoms in group sio2
group water type 2 13
17610 atoms in group water
group other subtract all sio2
26970 atoms in group other
group lipid subtract other water
9360 atoms in group lipid
region lower block -INF INF -INF INF -INF -15 units box
group lower region lower
4526 atoms in group lower
group lower_lipid intersect lower lipid
1201 atoms in group lower_lipid
#minimize
#minimize 1.0e-10 1.0e-12 100 1000
# fix nvt on water and lipid
fix 1 other nvt temp 323.15 323.15 100
# fix all tip3p water model
fix 2 water shake 1e-6 500 0 b 17 a 31
Finding SHAKE clusters ...
0 = # of size 2 clusters
0 = # of size 3 clusters
0 = # of size 4 clusters
5870 = # of frozen angles
fix rigid sio2 rigid molecule
1 rigid bodies with 354 atoms
# hold lower lipid bilayer
fix hold_lipid lower_lipid spring/self 10
# pull
fix pull sio2 smd cvel 50 -0.001 tether NULL NULL 37 0
# fix 2_sio2 sio2 nve
fix sio2 sio2 setforce 0 0 NULL
# compute sio2 sio2 reduce sum fz
# output forces acted upon sio2 sphere
#fix f_sio2 sio2 ave/time 1 500 1000 f_pull[3] f_pull[4]
f_pull[5] f_pull[6] f_pull[7] file f_sio2.addH.xx
# fix all
# generate initial velocity
velocity other create 323.15 1468 dist uniform
velocity sio2 set 0 0 -0.001 units box
thermo 10
thermo_style custom step cpu temp press f_pull[3] f_pull[4]
# 1fs per step
timestep 1
dump 1 all atom 10 dump.dppc.addH.xx
run 200000
Setting up run ...
Memory usage per processor = 105.505 Mbytes
Step CPU Temp Press pull[3] pull[4] pull[5] pull[6] pull[7]
0 0 323.2253 1.0353196e+15 3.5527137e-13
-3.5527137e-13 5.8980485 5.8996228 -3.5527137e-16
10 4.697108 1206.4801 -1.2635928e+15 0.032503132
-0.032503132 5.8880485 5.8889738 -0.00012854972
20 9.5625679 nan nan -1.0421669e-316
1.0421669e-316 5.8780485 nan -0.00072789367
30 10.417853 nan nan -1.0421669e-316
1.0421669e-316 5.8680485 nan -0.00072789367
40 11.277054 nan nan -1.0421669e-316
1.0421669e-316 5.8580485 nan -0.00072789367
50 12.133108 nan nan -1.0421669e-316
1.0421669e-316 5.8480485 nan -0.00072789367
60 12.990315 nan nan -1.0421669e-316
1.0421669e-316 5.8380485 nan -0.00072789367
70 13.847533 nan nan -1.0421669e-316
1.0421669e-316 5.8280485 nan -0.00072789367
80 14.706971 nan nan -1.0421669e-316
1.0421669e-316 5.8180485 nan -0.00072789367
90 15.563443 nan nan -1.0421669e-316
1.0421669e-316 5.8080485 nan -0.00072789367
100 16.418641 nan nan -1.0421669e-316
1.0421669e-316 5.7980485 nan -0.00072789367
Di Cheng
University of Science and Technology of China
Hefei, Anhui Province 230026
P. R. China
E-mail: [email protected]...
Tel.: +86-15321055911
