Dear LAMMPS users:
I am trying to run MD simulation phenol molecules using the Reax forcefield. First, after setting the initial parameters like the periodic boundary conditions, I minimized the configuration. Then, the system was heated up to 300 K using NVT and then I equillibrated the system at that temperature using NVT again. When I see the log file after each of the mentioned stages, I find that the values of Molecular energy and Bond energy are zero, but the Van Der Waals energy and Coulombic energy are nonzero. What's the problem. I appreciate any help regarding this problem.
Thanks.
Farshad Saberi
Mechanical Engineering Department, UAB
Dear LAMMPS users:
there is no problem. molecular energy is the sum of bond,
angle, dihedral and improper terms. neither of those
are accumulated with reaxx.
cheers,
Reax is a pairwise force field, in LAMMPS lingo. So all energy it
tallies is pairwise.
See the fix reax/bonds command for a way to get more stats out of a
ReaxFF model.
