[lammps-users] why the velocity profile is not linear?
Dear Steve,
I have run the example file for the NEMD simulation as bellow. I have added a line to moniter the velocity profile along the flow gradient direction. However, I found that the velocity profile was not linear as we expected (see attachment). How did this happen?
Thanks.
Input file:
2d NEMD simulation
units lj
atom_style atomic
dimension 2d
lattice sq2 0.8442
region box prism 0 10 0 8 -0.5 0.5 0 0 0
create_box 2 box
create_atoms 1 box
mass * 1.0
velocity all create 1.44 87287 loop geom
region slice block 4 6 INF INF INF INF
set region slice type 2
pair_style lj/cut 2.5
pair_coeff * * 1.0 1.0 1.0
neighbor 0.3 bin
neigh_modify delay 0 every 1
fix 1 all nvt/sllod temp 1.0 1.0 1.0 tchain 1
fix 2 all deform 1 xy erate 0.01 remap v
fix 11 all ave/spatial 1 10 10000 y lower 0.1 vx units reduced norm sample file vel.profile
dump 1 all custom 500 dump.nemd id type x y z
thermo 1000
run 50000
Could be any number of reasons - maybe you aren't averaging
enough samples. It looks like you only have 10 samples. Have
you tried visualiing the system - is it flowing correctly?
Dear Steve,
I have run the same simulation with a large sample size 1000. However, the velocity profile is still not linear as shown in the attachment. I have visualized the results. The box moves as under shear, which is also given in the attachment.
Ying Li
Picture3.emf (24.6 KB)
If the atoms are moving with the box, and you use
fix ave/spatial correctly, then you will get a roughly linear
profile.
