Hi Steve,
When we use the command of fix efield in simulations, can we get the work which is done by an applied electric field. For example, when we apply an external electric field along the axial direction of a carbon tube immersed into a water reservoir, water molecules will move through this tube. The calculation is based on the NVT system. Is the variation of the total energy of system is the work done by the electric field? if not, can you suggest me how to get it? Thanks.
Path Zhu
