Langevin damp
Hi Lammps users,
I am using fix Langevin as written in the Lammps documentation.
fix ID group-ID langevin Tstart Tstop damp seed keyword values
fix 1 all langevin 100.0 100. 1000 4827987
damp =1000, right.
Q1. My question is very simple what is the unit of this damp factor?
is it 1000fs or 1000ps ?
Q2. What is the relationship between damp and relaxation time?
Q3. Is relaxation time = damp*timestep?
if relaxation time is 50ps and timestep=10fs then Is it true that damp= 5000 ?
Q4. Suppose any paper mentions the Langevin friction coefficient is 0.01 ps^-1. then what is the value of damp?
Is it like this friction coefficient = mass/damp , let say mass = 1unit
so damp = 1/friction coefficient, i.e. , damp = 1/0.01 or damp = 100 ps ??
Q5 I want to know what is the default unit of damp factor in fix langevin.
all the questions, I assume in only real units.
It’s all there in the documentation :slight_smile:
The damp parameter is specified in time units and determines how rapidly the temperature is relaxed. For example, a value of 100.0 means to relax the temperature in a timespan of (roughly) 100 time units ( or fs or ps - see the units command). The damp factor can be thought of as inversely related to the viscosity of the solvent. I.e. a small relaxation time implies a high-viscosity solvent and vice versa. See the discussion about and viscosity in the documentation for the fix viscous command for more details.
https://docs.lammps.org/fix_langevin.html
That is what creates my confusion. damp = 100 time unit, so " in real unit " time unit is fs. It means that damp =100fs. Right ?
I read one paper where they were mention:-
simulations were performed at 300K for 5μs, with a time step of 10 fs. A Langevin thermostat was used, with a relaxation time of 50ps.
They wrote their langevin thermostat like this
timestep 10
fix fxnve all nve
fix fxlange all langevin 300 300 5000.0 32784
here damp = 5000 that means damp = 5000fs or damp = 5ps but
they mention relaxation time = 50ps which implies relaxation time has some connection with the damp factor and time step.
i.e. relaxation time = damp*timestep
now if we check,
relaxation time = 50ps and time step = 10fs then damp factor = 5000.
This means their paper’s description is wrong (good on them for making their original script available). I’ve seen much worse get past peer review. :slight_smile:
Ok then…if damp = 1000, then in real-time unit, it means that relaxation time = 1000fs or 1ps. :+1:
