I am trying to reproduce results from a paper by Thompson & Troian. Which has a lattice orientation as follows:
"x-direction of the fluid cell is aligned along the [11-2] orientation of the fcc lattice comprising the wall"&
"each wall of the cell consists of atoms forming two (111) planes of a fcc.
I have written the following statements in LAMMPS to reproduce it but I am not certain if it is correct.
I would greatly appreciate it if someone could confirm it or guide to some literature which could help me out.
Also I wanted to knw if there is a way to view only the wall atoms frm viewing axis along y direction in xmovie. I tried making the fluid atoms type as invisible but it shows a blank screen. In the other two viewing axis it performs as intended.
lattice fcc 0.81 orient x 1 1 -2 orient y 1 1 1 orient z 1 -1 0
create_atoms 1 region fluid units box
lattice fcc 3.24 orient x 1 1 0 orient y -1 1 0 orient z 0 0 1
create_atoms 2 region btm_wall units box
create_atoms 3 region top_wall units box
Thank you.
BR/Joseph
