Layer creation problem in ASE
Hello. I am trying to create 3 layers of calcite on the 1 0 4 surface and add vacuum to make a slab. Then to convert it to a 2x2 supercell. However, when I use the ASE code, I see it gives me only 3 angstrom thickness for the 3 layers, which is wrong. I tried to add bond lengths but still it did not work. Can anyone help me to create the slab?
This is the code I have used:
from ase.io import read
from ase.visualize import view
from ase.build import surface
Load the primitive calcite structure
bulk = read(‘calcite_primitive.cif’)
Create the (1, 0, 4) surface with 3 layers
surf = surface(bulk, (1, 0, 4), 3)
Add a vacuum of 20 Å along the z-axis (axis=2)
surf.center(vacuum=20, axis=2)
Define the Ca-O and C-O bond lengths
ca_o_bond_length = 2.36 # Å
c_o_bond_length = 1.29 # Å
Find Ca-O and C-O bonds and set their bond lengths
for i, atom_i in enumerate(surf):
if atom_i.symbol == ‘Ca’:
# Set bond length for Ca-O (search for nearby O atoms)
for j, atom_j in enumerate(surf):
if atom_j.symbol == ‘O’ and surf.get_distance(i, j) < 3: # Rough initial guess for Ca-O bonds
surf.set_distance(i, j, ca_o_bond_length, fix=1)
elif atom_i.symbol == 'C':
    # Set bond length for C-O (search for nearby O atoms)
        if atom_j.symbol == 'O' and surf.get_distance(i, j) < 2:  # Rough initial guess for C-O bonds
            surf.set_distance(i, j, c_o_bond_length, fix=1)
Visualize the surface after bond adjustment
view(surf)
Please put triple backticks (```) above and below the code to make it legible here.
Here is the code rewritten below:
from [ase.io](http://ase.io/) import read
view(surf)
calcite_primitive.cif (1.1 KB)
Here is the file which I have used to report the coordinates.
I’m working to reproduce simulations of a paper, in which i’m supposed to make a calcite block that’s consisted of calcite rhombohedral unit cell (10 atoms per unit cell), replicated 4 2 6 times in x y z axis and then add 25.6 angstrom vacuum in the x-axis, the block should contain 7680 atoms in total.
But when I use these dimensions, I get a few hundred atoms only. I have been trying to use different lattice parameters, but they didn’t give the required results.
What’s the possible solution? I came across your file, and I downloaded your CIF file so if I can use it to convert to LAMMPS format and use in the simulations.
